Branch tables
Programming Features - Command Branch Tables
Branch Tables
Command Branches
The table below cross-references the main prompt command keys, their internal command numbers, and where they branch.
When a user presses a key at the main prompt, Color 64 does not immediately jump to a routine based on the key itself. Instead, it performs a lookup:
  • The pressed key is first converted to its ASCII value.
  • The program searches the array CM%(I,1), which stores the ASCII value for each defined command key.
  • When a match is found, the corresponding array position becomes the command number in I.
  • The caller's access level is then checked against CM%(I,2), which stores the required level for that command.
  • If the key is valid and the caller has access, the value in I is then used by the branch tables beginning at line 13160.
In the table below, the value shown under No. is the command number ultimately stored in I.
Command Pre-Assignments
Key No. Key No.
@ 1 N 22
P 2 X 23
S 3 T 24
$ 4 L 25
D 5 + 26
# 6 Z 27
U 7 <blank> 29
! 8 1 30
F 9 2 31
C 10 3 32
A 11 * 33
O 12 5 34
G 13 6 35
H 14 7 36
W 15 8 37
M 16 9 38
I 17 % 39
E 18 = 40
↑ 19 & 41
> 20 - 42
< 21
For commands that are in the currently loaded overlay, there are ON GOTO statements to load a special "mini routine" specific to that command which exists in the line ranges 13200 to 13480 of the overlays. That mini-routine normally performs a GOSUB to the actual command routine, then does a GOTO 13100 to return to the main prompt.
This extra step exists because some command routines are also called from other places, such as the SYSOP menu. In those cases, the routine must perform its work without always forcing a return to the main prompt. The mini-routine provides a standard entry path for main-prompt commands while still allowing the underlying routine to be reused elsewhere.
The line numbers for these mini-routines are listed in the table below under the heading Mini.
How the ON GOTO branch tables work
The series of ON GOTO statements beginning at line 13160 is easier to understand if you think of it as a two-step dispatcher.
First, line 13160 chooses which group of commands is being handled. The commands are grouped into blocks of ten:
  • 0 to 9
  • 10 to 19
  • 20 to 28
  • 30 to 39
  • 40 to 42
Line 13160 does not jump directly to the final command routine. Instead, it jumps to the correct branch table for that group.
For example:
ON I/10+1 GOTO 13170,13180,13190,13195,13197
If I=7, then I/10+1 evaluates to 1, so BASIC branches to line 13170, which handles commands 0 to 9.
If I=24, then I/10+1 evaluates to 3, so BASIC branches to line 13190, which handles commands 20 to 28.
Once inside the proper group, a second ON GOTO chooses the exact destination within that group. Example:
13170 ON I+1 GOTO 13202,13205,13210,13220,92,92,92,92,96,13260
This line handles command numbers 0 through 9. BASIC uses I+1 because ON GOTO counts from 1, while the command numbers begin at 0.
So, if I=0, BASIC takes item 1 in the list and branches to 13202. If I=1, it takes item 2 and branches to 13205. If I=4, it takes item 5 and branches to 92.
The same idea is used for the later ranges, except the program subtracts an offset so the numbering again starts at 1 for that range:
  • ON I-9 GOTO ... handles 10 to 19
  • ON I-19 GOTO ... handles 20 to 28
  • ON I-29 GOTO ... handles 30 to 39
  • ON I-39 GOTO ... handles 40 to 42
This is why the branch tables can look confusing at first glance. They are not testing the key directly. They are using the command number in I, first to select the correct table, then to select the correct destination within that table.
Example
Using the code below:
13140 FOR I=. TO 42:IF ASC(A$)<>CM%(I,1) NEXT:GOSUB995:@
13145 @I=29 OR LV<CM%(I,2) OR I>39 AND M3=.
13150 #:GOSUB8004
13160 ON I/10+1 GOTO13170,13180,13190,13195,13197
13170 ON I+1 GOTO13202,13205,13210,13220,92,92,92,92,96,13260
13180 ON I-9 GOTO96,96,13290,96,96,96,13330,96,13360,13370
13190 ON I-19 GOTO92,13375,96,92,96,96,96,92,92
13195 ON I-29 GOTO35651,35652,96,98,100,96,96,96,96,96
13197 ON I-39 GOTO102,88,88
If the user presses P:
  • the search finds P in the command array
  • I becomes 2
  • line 13160 branches to 13170 because command 2 is in the 0 to 9 range
  • line 13170 evaluates ON I+1, which becomes ON 3
  • BASIC takes the 3rd item in that list, which is 13210
That is the mini-routine for the [P]ost a Public Message command.
If the user presses 3:
  • I=32
  • line 13160 branches to 13195
  • line 13195 evaluates ON I-29, which becomes ON 3
  • BASIC takes the 3rd item in the list, which is 96
Line 96 is an overlay loader, so command 32 is not handled locally in that overlay and must be relayed elsewhere.
Overlay Cross-Reference
The actual command routines are usually located in various places throughout the overlays. Sometimes an entire command is not fully contained in one overlay. For example, the [A]lter Password command must eventually branch to √bbs.init to change the password. In the table below, the overlay listed is the first overlay branched to. For the Alter Password command, that first destination is √bbs.ovl. The line numbers for the true underlying routines are listed under Actual.
Commands not present in the current overlay are sent to one of the overlay loader lines, which exist at lines 88 to 103. These lines load the overlay in which the command actually resides. The loader line is shown under Load, and the overlay abbreviation is shown under Overlay.
Before loading the new overlay, the variable OV is set so that the newly loaded overlay knows where to branch once loaded. Usually this is set to 1 automatically when the standard loader lines are used, because most overlays reserve OV=1 for a command relayed from another overlay.
Once the new overlay is loaded, the value in I is used again by the branch tables beginning at line 13160. In this way, the command number is preserved even though the command has been handed off to another overlay.
Sometimes the OV setting is not 1. This usually occurs in overlays that do not have a normal main prompt of their own, such as √bbs.init. In those cases, the loader must set a different OV value so the receiving overlay enters the correct routine.
OV Settings Cross Reference
Key No. Mini Actual Overlay Load OV Function
R 0 13202 3005 MSGS 90 1 Read Public Messages
@ 1 13205 3710 MSGS 90 1 Post Office
P 2 13210 1260 MSGS 90 1 Post a Public Message
S 3 13220 4005 MSGS 90 1 Scratch a Public Message
$ 4 13230 405 XFER 92 1 View Download Directory
D 5 13240 16505 XFER 92 1 Download File(s)
# 6 13245 16110 XFER 92 1 Choose a Download Directory
U 7 13250 16300 XFER 92 1 Upload a File
! 8 13255 27005 OVL 96 1 Edit User Stats
F 9 13260 7010 MSGS 90 1 Feedback to Sysop
C 10 13270 15002 OVL 96 1 Chat with the Sysop
A 11 13280 13735 OVL 96 1 Alter Password
O 12 13290 19010 OVL 96 1 Log off System
G 13 13295 13910 OVL 96 1 Select Graphics/ASCII/ANSI
H 14 13300 17015 OVL 96 1 View Help Files
W 15 13310 13310 OVL 96 1 View Welcome Files
M 16 13330 19510 MSGS 90 1 View Membership List
I 17 13350 13350 OVL 96 1 View Information File
E 18 13360 5010 MSGS 90 1 Edit a Public Message
. 19 13370 24005 INIT 95 2 Set Date & Time
> 20 13372 22010 XFER 92 1 DOS Wedge
< 21 13375 20010 INIT 95 7 Password Maintenance
N 22 13377 15505 OVL 96 1 New Downloads
X 23 13380 13810 XFER 92 1 Scratch a Download
T 24 13385 17010 XFER 96 1 Text Files Area
L 25 13380 8110 OVL 96 1 View Caller Log
+ 26 13400 35020 OVL 96 1 Multi-Upload
Z 27 13410 13710 XFER 92 1 Edit Download Description
Y 28 13420 14010 XFER 92 1 Release a Download
1 30 13430 14310 MSGS 90 1 Spare Command 1 (8.1a Games)
2 31 13440 13440 XFER 92 1 Spare Command 2 (8.1a User Profile)
3 32 13450 13450 OVL 96 1 Spare Command 3
* 33 13455 2000 OV2 98 1 Spare Command 4 (Mod Menu)
5 34 13460 OV3 100 1 Spare Command 5
6 35 13465 13465 OVL 96 1 Spare Command 6
7 36 13470 13470 OVL 96 1 Spare Command 7
8 37 13475 13475 OVL 96 1 Spare Command 8
9 38 13480 13480 OVL 96 1 Spare Command 9
% 39 13425 16050 OVL 96 1 Select Transfer Protocol
= 40 14005 NW1 102 1 Network Post
& 41 34010 NW2 88 1 Network Maintenance Menu
- 42 9010 NW2 88 1 Release Network Messages
? -- 13010 All Main BBS Menu
The Overlay Loader Lines
The table below defines the standard main overlay loader lines. Some of these lines are not present in every overlay because they may not be needed.
Standard Main Overlay Loader Lines
Line Overlay Line Overlay
89 √bbs.nw2 97 √bbs.ovl
91 √bbs.msgs 99 √bbs.ov2
93 √bbs.xfer 101 √bbs.ov3
95 √bbs.init 103 √bbs.nw1
35651 √bbs.games 35652 √bbs.profile
In overlays that have a main prompt, there is usually a line immediately before each loader line that sets OV=1. For example, to set OV=1 and load the √bbs.msgs overlay, use GOTO 90, which is one line before 91.
Individual Overlay Branching
The following sections describe how each overlay behaves depending on the setting of OV when the overlay is loaded. The path of GOTOs, GOSUBs, and overlay jumps is listed in a shorthand format.
Example path from √bbs.nw1:
OV=3 : 50, (12010), (12220), [6/INIT]
This regenerates the Net index from the Net Menu
In this notation:
  • Plain line numbers, such as 50, indicate a GOTO.
  • Line numbers in parentheses indicate a GOSUB.
  • A jump to another overlay is shown as [N/XXXX], where N is the new value of OV and XXXX is the destination overlay.
Using the example above, the actual flow would be:
5 GOTO 50
Line 5 is always the first branch point, where the overlay performs its ON OV GOTO dispatch.
50 GOSUB 12010:GOSUB 12220:OV=6:GOTO 95
Line 95 is the standard INIT loader.
In some cases this shorthand is slightly simplified from the exact code, but it provides a reliable map of the actual control flow.
The "OV" Settings for Overlays
The table below shows the paths for all defined settings of OV in the various overlays.
Path for OV Settings in Overlays
Line Command Setting
√bbs.init
OV=1 : 40, (19044), 30 Post-logoff procedures
OV=2 : 50, (12865), [3/MSGS] Set Date & Time (from main BBS prompt)
OV=3 : 60, (12760), 30 Back to Answer Feedback prompt (from √bbs.msgs)
OV=4 : 30, (12010), [2/MSGS] Wait-For-Call screen
OV=5 : 9999 Save msg index, variables, end program
OV=6 : 70, (12800), 30 Network Menu
OV=7 : 75, (20010), [3/MSGS] Password Maint (from main BBS prompt)
OV=8 : 80, (2710), [4/MSGS] Validate by E-mail
OV=9 : 78, (13735), [3/MSGS] Set new password (relayed from √bbs.ovl)
OV=10 : 65, (12092), [2/MSGS] End of midnight routine (back to WFC)
OV=11 : 35, (11905), 30 Reset √level x files
OV=12 : 85, (18240), [2/MSGS] Return to application routine (from NW1)
OV=13 : 33, (29010), 30 Return to WFC after new node applied
OV=14 : 79, (13735) Save User Profile from √bbs.profile
√bbs.msgs
OV=1 : 60, (13160), 57 Command relayed from other overlay
OV=2 : 50, <read √welcome2>, (13523), (8510), (9005), 55 Welcome msgs
OV=3 : 55, (13100), 57 Main BBS prompt
OV=4 : 70, (1410), <ON VX GOTO 71,72,55,74> General msg editor prompt
OV=5 : 65, (12822), [3/INIT] Answer SYSOP feedback
OV=6 : 80, (7020), 55 Feedback to SYSOP
OV=7 : 71, (9048), 55 Continue reading mail (after replying Net mail)
OV=8 : 72, (3675), (3320), 55 Continue reading msgs (after Net reply)
---- : 57, [3/OVL] Logoff
---- : 74, [3/INIT] Back to Answer SYSOP Feedback prompt
√bbs.xfer
OV=1 : 60, (13160), [3/OVL] Command relayed from other overlay
OV=2 : 65, (22010), [4/INIT] DOS command (from SYSOP Menu)
√bbs.ovl
OV=1 : 60, (13160), 80 Command relayed from other overlay
OV=2 : 70, (28005), (25005), (25100)
IF M3=0 THEN [10/INIT]
IF M3=1 THEN [7/NW1]
Purge old mail Validate disks Update download accesses
Continue midnight routine in INIT or Continue with Network midnight routines
OV=3 : 80, (19010), [1/INIT] Logoff
√bbs.nw1
OV=1 : 60, (14005), [3/MSGS] Post Network Msg (from main BBS prompt)
OV=2 : 40, (14005), [6/INIT] Post Net Msg (from Net Menu)
OV=3 : 50, (12010), (12220), [6/INIT] Regen Net index (from Net Menu)
OV=4 : 35 Illegal OV number (not used in v8.0+)
OV=5 : 67, (1110), (8010), (40000)
if carrier lock then [7/NW2]
if OK then (8010),(7520), [13/INIT]
Outgoing Net Send Update LOCK status Post-outgoing routines
OV=6 : 13110 Node login
OV=7 : 85, (12010), (12220), [8/NW2] Regen Net index (midnight routine)
OV=8 : 35 See OV=4
OV=9 : 35 See OV=4
OV=10 : 35 See OV=4
OV=11 : 30, (14490), [12/INIT] New billing entry (during application)
OV=12 : 35 See OV=4
OV=13 : 15, (7010), [7/MSGS] Private net reply (during e-mail reading)
OV=14 : 20, (7010), [8/MSGS] Private net reply (during public msgs)
OV=15 : 66, (12010), (12220), [11/INIT] Regen Net index (startup)
OV=16 : 74, (8010), [13/INIT] Continue outgoing after CARRIER LOCK
OV=17 : 35 See OV=4
OV=18 : 77, (40000), 72 Continue outgoing after Verify Net Mail
√bbs.nw2
OV=1 : 70, <ON I-40 GOSUB 3010,4010>, [3/MSGS] Relay from other overlay
OV=2 : 25, (3010), [6/INIT] Net Maintenance Menu
OV=3 : 30 Illegal OV number
OV=4 : 35, (7010), (7500), [6/INIT] Set window/speaker (from Net Menu)
OV=5 : 40, (11750), (18520), (18600), [15/NW1] System start-up routine
OV=6 : 50, (5001), [6/INIT] Send default net message (from Net Menu)
OV=7 : 55, (6050), (6220), [16/NW1] Update after CARRIER LOCK
OV=8 : 22, (21120), [10/INIT] Midnight routine; create √node x users
OV=9 : 27, (6290), (6600), [13/INIT] New node application
OV=10 : 23, (4010), [6/INIT] Release public net msgs (from Net Menu)
OV=11 : 30 See OV=3
OV=12 : 37, (6300), (6800), [18/NW1] Post-application to remote node
OV=13 : 47, (1110), [18/NW1] For use by Verify Net Mail mod
OV=14 : 65, (35440), (8100), [13/INIT] Distribute incoming Net data
Sysop Menu Branching
The table below shows where each menu command branches, by overlay.
Menu Branch Destinations
Key Line (+function, if applicable) Destination
SYSOP MENU - √bbs.init overlay
Routines begin at line 12510
F1 12100 Logon (Local Mode)
F2 12615 Load BBS term; if not found, return to 12010
F3 12635, (8100), 12010 View Caller Log
F4 12610
if M3=0 then (12865)
if M3=1 then (12800), 12010
Set Date & Time, or go to Net Menu
F5 12630, (12710), 12010 Read Feedback to Sysop
F6 12620, (20010), 12010 Password Maintenance
F7 12625, [3/XFER] DOS Wedge
F8 12640, 9999 Shut BBS down
NETWORK MENU - √bbs.init overlay
Routines begin at line 12800
F1 12865, (24005), 11920 Set Date & Time
F2 12850, [4/NW2] Set Net window/speaker
F3 12835, [2/NW2] Net Maintenance Menu
F4 12855, [6/NW2] Default Net message multi-send
F5 12840, [10/NW2] Release public Net messages holding
F6 12860, [3/NW1] Regenerate Network index
F7 12845, [2/NW1] Post Network Message
F8 Return to WFC
NETWORK MAINT MENU - √bbs.nw2 overlay
Routines begin at line 3010
1 3080 Billing List/Print
2 3160 Billing Edit
3 3300 Billing Report Generator
4 3450 Billing Total Accounts
5 6010 Node Status Report
6 7110 Node Account File Edit
7 7600 Attach File
8 3072 Read Send Log
9 3073 Read Receive Log
Midnight Routines
The midnight maintenance routines begin in the √bbs.init overlay and continue through several other overlays. The table below maps this process.
Midnight Maintenance Routine Paths (√bbs.init)
Line Command Branch and Functional Area
INIT : (26210), [2/OVL] Call to 26210 resets time limits
2/OVL : 70, (28005), (25005), (25100),
if M3=0 then [10/INIT]
else if M3=1 then [7/NW1]
Calls to:
  • 28005 - purge old mail
  • 25005 - validate disks
  • 25100 - update download access count
7/NW1 : 85, (12010), (12220), [8/NW2] Calls to:
  • 12010 - regenerate Network index
  • 12220 - count public Net messages holding
8/NW2 : 22, (21120), [10/INIT] Call to 21120 creates √node x users
10/INIT : 65, (12092) Call to 12092 ends the midnight routine and returns to WFC
Next section: Absolute Day Numbers (ADN)
