Help and text
Installation - Help & Text Files
A complete set of Help Files is included with the Color 64 package, but no Text Files are provided by default. Help Files and Text Files function identically, so the included Help Files serve as a model when creating your own Text Files.
There must be a file on the Help Files disk called "@help files". Notice that this filename begins with an “@” symbol instead of the check mark (√). The “@” prevents the file from appearing in download directories, while still allowing remote SYSOPs to download, scratch, or re-upload it as needed. In practice, any user can download these help files if you provide instructions. This is particularly useful for callers whose terminal software does not support ASCII capture.
Both Help Files and Text Files are optional features. However, it is strongly recommended that at least the Help Files be available, especially for users new to the BBS scene.
The "@help files" file acts as a menu. When displayed, it should instruct callers which number to enter to read a specific help file. The format of this menu is entirely up to you. It may be simple text or full graphics, and the numbering does not need to be sequential if you prefer a custom layout.
Each help file on disk must follow this naming convention:
@help1 @help2 @help3
When a caller enters “1”, the BBS will load and display "@help1".
Text Files operate in the same way, except the menu file must be named "@text files", and the individual files follow this format:
@text1 @text2 @text3
If the "@text files" menu file does not exist, callers selecting Text Files will see a message stating that none are available. The same behavior applies if "@help files" is missing.
There is no internal limit to the number of Help or Text files you may create beyond available disk space. If you anticipate exceeding the standard BBS message line limits, use the stand-alone message editor (+EDITOR), which allows messages up to approximately 500 lines.
Be creative when designing Text Files. They can help define the personality of your BBS. Examples might include current news, Color 64 BBS lists, recipes, movie reviews, technical notes, or hobby content relevant to your audience.
After editing your system messages, use a file copier to copy all sample Help Files to the drive designated in the SETUP Drive Assignments section. Then use the Message Editor to read and, if desired, modify each file. These Help Files serve as both documentation for your users and a guide to understanding the system’s features.
Next Section: Email Notification Option
Installation
