System Tracing
BBS.INIT
The following are breakdown of routines found in BBS.INIT - this is under construction.
bbs.init Overlay
Overview
The bbs.init overlay is the main startup and idle-state overlay for Color 64 BBS. It is the first overlay run when the BBS starts and remains active while the system is waiting for a caller.
This overlay is responsible for several core system functions, including:
- Loading system parameters
- Starting the BBS
- Managing the idle and waiting-for-call state
- Reading and updating user records
- Daily system maintenance
- Caller log file maintenance
- Scheduled network checks
- Program error handling
- Crash recovery
- Saving system data during shutdown
Routine Summary
| Lines | Function | Description |
| Overlay Control | ||
| 5-85 | Overlay Return Control | Uses the value of OV to determine which routine should run when control returns to bbs.init. |
| 89-104 | Overlay Selection | Builds the filename needed when another overlay must be loaded. |
| Input and Output | ||
| 105-160 | Character Input and Output | Performs character input, output, carrier detection, and carriage return handling. |
| 202-280 | Display Text File | Opens and displays a text file while checking for disk errors. |
| 300-380 | Read User Input | Reads a line of text from the caller or local keyboard. |
| 390-400 | Trim Input | Removes leading and trailing spaces from entered text. |
| Drive and Disk Control | ||
| 460-489 | Select Drive | Selects the configured device, drive, partition, or directory and processes any associated drive commands. |
| 505-580 | Disk Status | Reads the disk drive status and reports disk errors. |
| 710-795 | Get File Size | Returns the size of a file in Commodore disk blocks. |
| User File Control | ||
| 910-946 | Load User Record | Loads a user record from the user file. |
| 2710-2790 | Update User Record | Loads, updates, and saves another user's record during Sysop maintenance. |
| 9450 | Scratch Private User File | Deletes a private file associated with a user account. |
| Caller Log File Control | ||
| 8003-8010 | Buffer Caller Log | Adds text to the caller log buffer. |
| 8020-8031 | Write Caller Log | Writes buffered caller log data to disk. |
| 8032-8033 | Process Drive Commands | Processes drive commands associated with the caller log drive. |
| 8034-8035 | Find Command Channel | Locates or assigns a disk command channel for caller log operations. |
| 8036-8040 | Caller Log Error | Reports and records caller log disk errors. |
| 8100-8170 | Caller Log Utilities | Displays, manages, or scratches the caller log. |
| Time and System Maintenance | ||
| 1110-1180 | Read Clock and Date | Reads the current time and date and detects when a new day begins. |
| 10645-10647 | Regenerate Message Index Prompt | Prompts the Sysop during startup to optionally regenerate the message index by deleting the saved index file. |
| 10800-10820 | Load Message Index | Loads the saved message index during startup. If the index file is missing or cannot be opened, processing automatically branches to the regeneration routine. |
| 11210-11500 | Regenerate Message Index | Rebuilds the message index from the public message directory, sorts the results, and rebuilds the associated message information. |
| 1521-1525 | Remove Empty Message Base | Removes an unused message base entry. |
| 9810-9826 | Save Message Index | Saves the message index and related system variables. |
| 9991-9992 | Log Program Error | Records BASIC program errors for caller log entry during crash. |
| 9999 | System Shutdown | Saves system information, closes files, restores the environment, and shuts down the BBS. |
| BBS Entry Processing | ||
| 12950-12990 | Modem polling | Monitors the modem while the BBS is in the Wait For Caller state and detects incoming calls. |
| 13010-13060 | Network ops - NW1 | Calling OV 5 for NW1 |
| 13650-13695 | Logoff processing | Cleanup items for logoff |
| 13899 | Local Login from console | Invoked by pressing F1 on Sysop Menu at WFC |
| 13910-13930 | Login processing (initial) | Initial login processing for user |
| 18110-19099 | New User Processing | Processing for new user registration and creation |
| 18500 | Open Password File | |
| 19110-19120 | Invalid Sign-on Detected | Processing for invalid credentials |
| 19510-19595 | Present Membership List | Display membership list to user |
| File Area Support | ||
| 16010-16012 | Select File Directory | Selects the configured upload or download directory. |
| Maintenance Duties | ||
| 20010-22000 | User File/Password Manager | Editing of the User database (Password Maintenance) |
| 24005-24400 | Date & Time Modification | System Date and Time Edit by Sysop |
| 26210-26320 | Time Limits Reset routine | **resume** |
| Caller Log Maintenance | ||
| 28570-28590 | Check Caller Log Size | Checks the caller log size and performs maintenance when needed. |
| 28655 | Load ASCII Support | Loads the ASCII support module when required during caller log processing. |
bbs.msgs Overlay
Overview
The bbs.msgs overlay provides the primary public-message and private-mail functions of Color 64 BBS. It also contains the shared message editor and several supporting caller and SYSOP functions.
This overlay is responsible for several message-related functions, including:
- Reading and posting public messages
- Organizing messages by category and subject
- Editing, scratching, linking, and changing message categories
- Sending and reading private mail
- Holding, deleting, forwarding, and replying to private mail
- Sending feedback
- Displaying SYSOP News
- Displaying the membership list
- Providing SYSOP chat
- Processing commands while the overlay is active
Routine Summary
| 1-106 | Overlay Return Control | Uses the value of OV to determine where processing begins when bbs.msgs is loaded or resumed. |
| 89-104 | Overlay Selection | Builds the filename needed when another Color 64 overlay must be loaded. |
| 9991-9999 | Error and BREAK Handling | Records the error or BREAK condition, closes open files, and returns control to bbs.init. |
| 13010-13525 | Main Command Processing | Accepts caller commands, checks access levels, runs local message functions, or loads another overlay. |
| 35651-35652 | Additional Overlay Selection | Loads bbs.games or bbs.profile when requested. |
| Input, Output, and File Control | ||
| 110-1180 | Shared System Routines | Provides keyboard input, text-file display, disk selection, disk-status handling, confirmation prompts, and date and time processing. |
| 60050-60051 | Open Sequential File | Opens a sequential file and optionally checks the resulting disk status. |
| Message Creation and Editing | ||
| 1260-1598 | Create and Store Message | Creates message headers and stores completed public messages, private mail, feedback, and forwarded mail. |
| 1300-2975 | Message Editor | Provides message entry, word wrap, listing, editing, insertion, deletion, MCI control, autosignatures, sending, and aborting. |
| 36000-36010 | Load Autosignature | Loads the current caller's saved signature for use in the message editor. |
| Public Message Control | ||
| 3005-3690 | Read Public Messages | Displays message categories, determines unread messages, follows subject chains, and processes message-reader commands. |
| 3900-3945 | Display Public Message | Reads and displays the message header, routing information, subject, and message body. |
| 4005-4095 | Scratch Public Message | Deletes an authorized public message and repairs the message index and subject links. |
| 4210-4298 | Change Message Category | Moves an authorized message to another accessible category and updates its filename and message-index entry. |
| 4510-4590 | Change Message Link | Removes a message from its current subject chain and links it to another subject. |
| 4610-4697 | Select Existing Subject | Allows a caller posting a message to browse existing subjects and add the new message as a reply. |
| 5010-5180 | Edit Public Message | Loads an authorized public message into the editor and stores the revision under its original message number. |
| 36500 | Message Ownership Error | Informs the caller that the selected message does not belong to them. |
| Post Office and Private Mail | ||
| 3710-3750 | Post Office Menu | Provides access to private mail, public-message posting, feedback, and the membership list. |
| 7010-7021 | Send Feedback | Sends feedback to the SYSOP or allows an authorized caller to select another private-mail recipient. |
| 9005-9450 | Read Private Mail | Scans the caller's mailbox and provides reread, delete, hold, forward, and autoreply functions. |
| 9500-9650 | Hold and Forward Mail | Rebuilds held mail, forwards private mail, and supports local carbon copies. |
| 12820-12885 | Select Mail Recipient | Resolves member names and numbers, verifies recipients, and routes local or network private mail. |
| Caller and SYSOP Functions | ||
| 8510-8560 | Display SYSOP News | Displays SYSOP News dated on or after the current caller's last-called date. |
| 12800-12816 | Temporary User Settings | Allows the local SYSOP to temporarily change the online caller's access level, time, transfer totals, or local/remote state. |
| 13600-13695 | Online Status and Connection Handling | Displays caller status, checks remaining time, processes shared input, and handles a lost connection. |
| 15915-15940 | Modem Response Handling | Sends modem commands and waits for the expected response. |
| 18500 | Open Password File | Opens the password file for member-name and member-number verification. |
| 19010-19099 | Logoff and Cleanup | Calculates remaining time, displays the logoff file, and removes temporary private-mail files. |
| 19510-19595 | Membership List | Displays the complete membership list or searches it using a caller-supplied pattern. |
| 35700-35932 | SYSOP Chat | Provides direct communication between the local SYSOP and the remote caller. |
| Logging and Session Events | ||
| 8003-8010 | Buffer Caller Log | Adds message-related activity to the caller log buffer. |
| 8020-8031 | Write Caller Log | Writes buffered caller log information to disk. |
| 8032-8040 | Caller Log Drive Handling | Processes drive commands and records nonfatal caller-log disk errors. |
| 35950 | Session Event Summary | Adds message and private-mail activity to the session event buffer. |
bbs.xfer Overlay
Overview
The bbs.xfer overlay provides the primary file transfer functions of Color 64 BBS. It manages uploads and downloads using XMODEM and Punter protocols, maintains download directories and upload descriptions, performs transfer accounting, and provides several SYSOP utilities including DOS commands, file copying, and SYSOP chat.
This overlay is responsible for several transfer-related functions, including:
- Uploading and downloading files
- Multi-file downloads
- Upload descriptions
- Download directory maintenance
- Download credit accounting
- Transfer time estimation
- Upload hold processing
- SYSOP DOS utility
- SYSOP chat
- Loading Games and Profile overlays
Routine Summary
| 1-106 | Overlay Return Control | Uses the value of OV to determine where processing begins when bbs.xfer is loaded or resumed. |
| 9991-9999 | Error and BREAK Handling | Records the program error or BREAK condition, closes open files, and returns control to bbs.init. |
| Shared System Routines | ||
| 110-1180 | Shared System Routines | Provides keyboard input, text-file display, disk selection, disk-status handling, confirmation prompts, and date/time processing. |
| 19010-19099 | Logoff and Cleanup | Calculates remaining time, displays the logoff file, and removes temporary upload files. |
| File Transfer Processing | ||
| 15915-15940 | Modem Response Handling | Sends modem commands and waits for the expected modem response. |
| 16020-16050 | Configure Punter Block Size | Allows the SYSOP to configure the Punter transfer block size. |
| 16060-16085 | Load Transfer Module | Loads the XMODEM or Punter machine-language transfer module. |
| 16110-16230 | Select File Directory | Displays the configured upload or download directories and selects an accessible directory. |
| 16300-16498 | Upload Processing | Validates filenames, checks for duplicates, creates upload descriptions, performs file transfers, processes upload confirmation, updates download directories, and records upload statistics. |
| 16505-16610 | Download Processing | Validates download requests, displays upload descriptions, performs file transfers, updates download credits, and records completed downloads. |
| 16680-16695 | Transfer Completion | Waits for transfer completion, checks disk status, and processes transfer errors. |
| 16700-16720 | Transfer Abort Handling | Displays aborted-transfer messages and waits for caller acknowledgement. |
| 16750-16760 | Upload Description Editor | Creates and edits the upload description associated with a transferred file. |
| 16800-16990 | Transfer Estimation and Setup | Calculates transfer size and estimated transfer time, verifies available online time and download credits, displays transfer statistics, and initializes protocol-specific transfer options. |
| File Directory Management | ||
| 402-445 | Display File Directory | Displays download directory listings and available disk space. |
| 6005-6999 | Download Directory Maintenance | Adds, edits, scratches, releases, and updates download-directory entries. |
| 12800-14170 | File Maintenance Commands | Performs SYSOP file maintenance including release, scratch, description editing, and related download-directory operations. |
| 15605-15690 | Multi-file Download Preparation | Builds the multi-file download queue, validates requested files, and calculates cumulative transfer time and download credits. |
| SYSOP Utilities | ||
| 19100-19122 | SYSOP Status | Toggles SYSOP availability and email notification status. |
| 22010-22655 | SYSOP DOS Utility | Provides direct DOS command access, directory display, file viewing, file copying, device selection, and Message Maker access. |
| 22701-22712 | Explicit SYSOP Status | Sets the SYSOP in-office or out-of-office status. |
| 8003-8010 | Buffer Caller Log | Adds transfer-related activity to the caller log buffer. |
| 35950 | Session Event Summary | Adds upload and download activity to the session event buffer. |
